Fluent Simulation of gas mixture in the pipe
Old   November 25, 2016, 01:35
Smile Fluent Simulation of gas mixture in the pipe
Rauf
free.man is on a distinguished road
hello everyone.
i am doing some simulation of fluid flow in the 90 degree bending pipe. i want to know relation of velocity inlet variation, compressibility, and pressure drop for mixtures gas flow.
this is my setup:
1. fluid is natural gas (11 species of mixtures gas), modeled as incompressible-ideal-gas. i am considering to use ideal-gas model later. or any suggestion?.
2. velocity will be varied from 0.5 m/s until 180 m/s (velocity, mach number, and Reynolds number attached below).
3. pressure of the system is 0.3 atm(gauge).and environment pressure 1 atm.
4. i use k-w SST turbulent model (my reason is because flow will be always in entrance region, so k-e is not applicable) CMIIW.
my questions are:
1. the fluid is modeled as incompressible-ideal-gas. i am considering to use ideal-gas model later. or any suggestion sir?.
2. based on march number, it will be incompressible and compressible flow can i use pressure based ??. or switch to density based when mach > 0.3 ?
3. where to input the pressure of the system ?. i tried to input inlet pressure gauge 0.3 atm but the result is similar with inlet pressure gauge 0 atm.
4. in some compressible flow simulation tutorial, i saw that they using inviscid model (because of very high Reynolds number). for my model, which one will be better, stay using turbulent model or switch to inviscid ?.
5. i open any suggestion .
thank you for advice.
regards,
free.man
free.man is offline   Reply With Quote
Old   November 26, 2016, 01:59
Unhappy
Rauf
any suggestion??
mach number, mixture of gases, pipe flow, pressure based solver
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
LSR (Land speed record) car simulation on FLUENT Maxime31850 FLUENT 2 May 1, 2013 12:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
gas expansion in pipe crack propagation Marco Evangelos Biancolini Main CFD Forum 2 October 4, 2000 11:41
