November 23, 2016, 17:36 |
temperature does not change in heat transfer
Hi I am now working on case, which is simple: a power module (copper) has film-type heat sources on one side and has hundreds of pins on the other side. Cooling fluid flows through the pins and exits through outlet. In order to make it simple, the model contains only power module (solid) and cooling fluid. The inlet and outlet BC are defined as constant mass flow rate and pressure-outlet. For the wall-powermodule-fluid and wall-powermodule-fluid-shadow, both are defined as coupled heat transfer. However, when I ran the case, the temperature of the power module and the fluid does not change, both maintaining the value of inlet temperature. Did I miss something or set some incorrect parameters? Thanks for any inputs!
UDF to change heat transfer coefficient with wall temperature | emmkell | Fluent UDF and Scheme Programming | 18 | August 7, 2018 03:44 |
transient source term | strakakl | OpenFOAM | 38 | November 19, 2013 01:18 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Convection heat transfer with unknow stream temperature | moienfar-CFD | FLUENT | 3 | February 22, 2013 10:49 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
