November 19, 2016, 16:39 |
Problem with 'Mapped Face Meshing'
Robert
Rep Power: 11 |
I work on the 2D simulation of the airflow created by the two converging air jets (Ansys Fluent 15.0, Workbench). I use mapped face meshing option for my meshing final structure. Once I save the meshing, I update the setup in workbench and open the setup program. During the model loading in the setup program, this communique pops up: 'Error at host: zone-surface: invalid thread[2]' (please also see picture 1 and 2 attached). Simultaneously, in Setup->Solution Setup-> Boundary Conditions a 'wall surface body' entity appears, next to inlet, outlet, wall, etc. When I do not use mapped face meshing I do not have this problem. There are no errors and wall surface body does not appear. I do not know the reason of this problem. I searched the internet but no luck. P.S. When I mesh my geometry I use edge sizing option first, stating the element size, and then I use mapped face meshing. I also enclose the two pictures of my geometry (pictures 3 and 4). As seen on picture 4 some of the quadrilateral cells are slightly skewed but without mapped face meshing they are skewed even more. Please help. Regards |
[ANSYS Meshing] Inflation in Mapped Face Meshing | gill11a | ANSYS Meshing & Geometry | 13 | August 28, 2022 13:26 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
