Calculation of drag and lift coefficient in flow around a semi-cylinder shape |
November 18, 2016, 13:47 |
I'm trying to perform a transient simulation of flow around an airfoil.
The simulation is at Re=50000 with an incompressible fluid. As expected i found oscillatory drag and lift coefficients due to the beginning of von karman vortexes phoenomena. I'm performing different simulation maintaining the Re=50000, but changing parameters like material's viscosity and density, and velocity inlet, to analyze the sensitivity of these drag and lift coefficients. I supposed that at same Reynolds and same shape of the airfoil, these coefficients are almost constant (reading some paper i found tabulated values for differently shaped airfoils). Actually happens that increasing the velocity by a factor 10 ^2 these coefficients are scaled by the same factor. How can I explain this behaviour? Thank you very much for the help, I can't find a logical explanation. |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
How to compute lift and drag coefficients for flow past a fixed cylinder? | antonella.longo@ingv.it | Main CFD Forum | 2 | May 11, 2016 17:26 |
Drag and lift coefficient for supersonic flow | Nick R | Main CFD Forum | 0 | September 28, 2014 02:25 |
Laminar flow over a cylinder_lift and drag coefficient | ssmeherk | OpenFOAM | 0 | February 18, 2014 07:29 |
Coefficient DRAG and LIFT - Cylinder 3D | Jwolf | CFX | 11 | February 4, 2010 05:08 |
