Comparing loss coefficients with experiment and CFD
Old   November 18, 2016, 09:36
Default Comparing loss coefficients with experiment and CFD
mariejanethompson is on a distinguished road
I am simulating turbulent flow around a 90 degree bend and calculating the pressure drops across it. An experiment was previously carried out in order to validate my cfd.
In the experiment piezo meters were used at pressure tappings before and after the bend, and the change in pressure due to the height differences in the piezos was calculated using ρgΔh. Bernouill's was then calculated and subtracted from this in order to find the minor loss? And then the minor loss coefficient calculated from this.
In fluent, I get pressure readings before and after the pipe using monitors. I subtract them from each other to get the pressure loss. From here I am unsure what to do. Are the pressures from the monitors major loss? Does Bernoulli's need subtracting from this as well in order to find the minor loss and the minor loss coefficient in order to make a comparison with the experiment?
Any help will be much appreciated!
mariejanethompson is offline   Reply With Quote
Old   November 18, 2016, 17:29
Lucky
I'm not sure what you mean by Bernoulli's was calculated and subtracted.
However, you should do the exact same thing that was done in the experiment. There is no sense in doing it any other way if you are trying to compare the two.
bend, loss coefficient, pipe, pressure losses, turbulent
Looking for help with a CFD project, mimicking a wind tunnel experiment thewalrus CFD Freelancers 1 November 3, 2016 14:25
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
Problem comparing CFD results with experiment. Sogolpb89 Main CFD Forum 2 April 18, 2015 13:59
Francis turbin difference between experiment values and CFD 2 snoopy CFX 7 January 7, 2010 18:10
CFD v Experiment for Radial Fan Alan Davis Main CFD Forum 7 April 24, 2001 13:15
