How to create a ground plane in Ansys Fluent
Old   November 15, 2016, 22:29
Default How to create a ground plane in Ansys Fluent
SK
jskpk is on a distinguished road
I want to analysis wind load on a building. So I built a building and when i tried to applied the enclosure i found that the enclosure size must be bigger than 0 which means the building's bottom surface was not connected to ground.
The attachment is what i want to get. I assume I have to build a ground surface to to that but i dont know how. Pardon my awkward English and thanks first.
jskpk is offline   Reply With Quote
enclosure, fluent
Create Mid plane in fluent Goutam FLUENT 0 February 20, 2015 19:44
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
Results are different for Ansys Fluent 14.0 and Fluent 6.3 syavash Fluent UDF and Scheme Programming 1 February 17, 2013 02:09
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
export data from fluent to ansys galapago FLUENT 0 August 4, 2010 15:04
