running fluent in HPC server
Old   November 4, 2016, 10:40
Default running fluent in HPC server
Aseel
Ad.Al.Qads is on a distinguished road
Hello everyone .
can you please help me in this and share your knowledge ?
i am running ice simulation using hpc server in parallel mode and when i check the output file it keep showing me these errors.
how can i avoid this errors and how to get the pictures and the animation of the report file as it is available when i run in my laptop .
the errors is as followss:
Error: No graphics functions are available.
Error Object: ()
/dis s-w 2/dis set cont surf ( ice_cutplane_1 )
Error Object: ()
Error Object: ()
/dis set pic driver jpeg/dis set cont filled-cont yes/dis cont velocity-magnitude , ,/dis view rv ice_cutplane_1-viewinvalid command [ice_cutplane_1-view]
Error: hardcopy-window: No active window.
Error Object: #f
/dis hc ../Report/ice-velocity-magnitude-on-image1-CA_0108.000.jpg#f
(wb-ice-write-iterations-per-time-step)
Error: sopenoutputfile: unable to open file for output
Error Object: "../Fluent/ice-iter-per-timestep.out"
#f
Warning: multiple subdivision required on zone 10. Subdivide using Constant Ratio.
reversed flow in 286 faces on pressure-outlet 31.
**sometimes the simulatin will jump to another iteration for example it will jump from iter 8 to iter 14 and the the lines between these iteration is as foloows :
" gy k epsilon time/iter
temperature limited to 2.500000e+02 in 260 cells on zone 18 in domain 1"
Thank you
Ad.Al.Qads is offline   Reply With Quote
Old   November 4, 2016, 11:11
Aseel
attached the picture of the errors form the output file in hpc server
thank you
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Problem running fluent with udf on batch tobi b. Fluent UDF and Scheme Programming 3 April 14, 2016 14:54
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Fluent.. lmgrd is not running shrikant_fromchicago Main CFD Forum 0 March 2, 2010 02:31
FLUENT 5.2.3 running on PIII 733 Burley Wang FLUENT 7 April 19, 2000 07:03
