November 2, 2016, 14:15 |
turbine blade pitching UDF
Mike McManuc
Rep Power: 10 |
I'm hoping someone could help with a UDF, I want to control the blade pitch of a vertical axis turbine using a UDF, I was able to control the pitch using the UDF (see below) provided on this form by mahditorabiasr. but in my model I dont have a function that I can assign to control the pitch, instead I have a known pitch angle from North for each azimuth position 0-360, could someone explain to me how I could read these positions into my UDF if possible and how I would apply it within the UDF #include "udf.h" DEFINE_ZONE_MOTION(pitching_blade,omega,axis,origi n,velocity,time,dtime) { real theta0, thetap1, omegac, omegar, radius, pi; pi = 3.141592654; omegar = 1; /* pitching velocity of blade [radians/s] */ omegac = 3.6; /* angular velocity of rotor [radians/s] */ theta0 = pi/2.; /* initial angular position of blade origin [radians] */ radius = 0.5; /* radius of rotor [m] */ thetap1 = omegac*(time+dtime); /* angular change from initial position at t+dt */ *omega = omegar; /* pitching velocity of blade */ /* time-varying origin of the local rotor zone coordinates in meters */ origin[0] = radius*cos(theta0+thetap1); origin[1] = radius*sin(theta0+thetap1); origin[2] = 0.0; } Thanks in advance, Mike |
November 3, 2016, 14:00 |
Mike McManuc
Rep Power: 10 |
What I want to do, is adjust the above UDF from having a blade pitching velocity denoted as "omegar" to a blade pitch angle per azimuth position
I was thinking If i read in the blade azimuth and pitch angles and specified an "If statement" saying that if theta(azimuth) was X then Beta(pitch) would be some function of X, does anyone know how this is done? more preferably I read in the theta and beta values and for each theta I have a beta value and this would replace the omegar value in the original UDF. or would I still need to include this omegar value but set it at the same value as the turbine rotation speed (omegac), as I have a beta for every theta. I hope I have explained this clearly enough. I would be extremely grateful if someone could help out with this. Thanks Last edited by BigMc; November 3, 2016 at 14:13. Reason: typos |
fluent - udf - parallel, mesh, pitch change, pitching aerofoil, udf and programming |
Does anyone have 3D blade profile of wind turbine? | kenya0514 | Main CFD Forum | 5 | March 9, 2015 15:06 |
blade angles of turbine blade | ganesh chakravarthi | ANSYS Meshing & Geometry | 0 | December 10, 2014 04:42 |
Wind Turbine Blade rotation | mmd_knr | FLUENT | 1 | August 8, 2012 15:52 |
Verifying results for a wind turbine blade simulation in ANSYS CFX | Joystix | CFX | 3 | April 27, 2012 18:52 |
[Other] ANSYS CFX-Meshing problem of a wind turbine blade | Zoe | ANSYS Meshing & Geometry | 1 | July 14, 2010 03:02 |
