Interface between static and rotating cell zone
Old   October 31, 2016, 06:24
Default Interface between static and rotating cell zone
khairil hafizi
bobdorm14 is on a distinguished road
I have a problem regarding the interface between a rotating and static cell zone. Which settings do i need to adjust in Fluent to have a correct simulation? The case is pretty simple. I have a rotating cell zone which update based on calculation made in UDF dynamic mesh.
I set both the rotating and static domain as fluid zone.the problem ,there is pressure different at the border between rotating and static zone as the circle domain start to rotate.I only set airfoil as the wall.supposed there is*only pressure on the airfoil as fluid interact with wall (airfoil).
for dynamic mesh,the airfoil and rotating domain was set as rigid body and both the node position will update simultaneously at each time step.
the velocity was set at the left side and pressure outlet at the right side on the static cell zone.
can anybody help ..
bobdorm14 is offline   Reply With Quote
Old   November 1, 2016, 06:30
david glynn
davd4696@gmail.com is on a distinguished road
have you created an interface boundary cndition between your static and rotating domains?
davd4696@gmail.com is offline   Reply With Quote
Old   November 1, 2016, 09:19
khairil hafizi
hi David
yes I created the interface under 'mesh interface' and periodic boundary condition selected under 'interface option'
I created two different domain with two different parts in geometry modeler.
I inspected there is a little gap at the border between these domains.
I think that is not the problem as I set both as fluid cell zone..
Old   November 2, 2016, 06:36
david glynn
It looks to me that your interface is set up incorrectly, have you created a named selection for the static edge and the rotating edge and used these to created your interface?
fluent, interface
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Interface between rotating and static zone Dog92 FLUENT 2 July 28, 2016 14:42
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
