October 29, 2016, 12:11 |
Low Coefficient of Moment for VAWT, 2D,
Hi everyone,
I'm doing a study on H-type VAWT, I experience a contradict result from FLUENT, the Coefficient of moment generate from monitor is extremely small. I wonder if you guys could give me some advised. Set up Chord length is 0.2 meter, 3 Blades Vinf = 6 m/s Reference length, radius of turbine = 2; Reference Area, Diameter of turbine, 4; Solver SIMPLE, Least square cell based, PRESTO!, Second order for the rest Viscosity is standard K-epsilon, with Standard wall function. The graph for CM is as expect from VAWT, the only thing that not normal is the small magnitude of the CM, after average it in the steady state region , which result in a very small Cp, and even negative when TSR = 4. Any ideas? Thanks everyone! T. Olsen |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
calculate pitching moment coefficient | jyh3134 | FLUENT | 0 | January 30, 2013 11:40 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
plotting drag coefficient in low reynolds number flow past cylinder | atmcfd | FLUENT | 0 | January 2, 2010 09:34 |
Help for monitor Moment coefficient in Fluent | James | FLUENT | 0 | April 16, 2008 23:58 |
