Creating multiple sections in domain in CFD-Post |
October 29, 2016, 12:06 |
Ravi Agrawal
Rep Power: 13 |
Hi, I modelled turbulent flow and heat transfer in a 3D pipe in Ansys-Fluent. During post-processing in CFd-Post, I need to obtain local heat transfer coefficient on inner wall. For that I need to make about 200 cross-sections at different axial locations. Is there any way to make these sections at once rather than doing manually one by one. I have to do same operation on 20 other cases.
I also have to make same number of poly-lines in domain. I guess, method to do that would be same as that for multiple cross-sections. Any suggestion is appreciated. Regards. |
October 30, 2016, 10:19 |
Green
Rep Power: 10 |
Well, I am not an expert user and I don't have ANSYS by hand. But maybe you can try journals.
https://www.sharcnet.ca/Software/Ans...p_wmjs326.html |
October 31, 2016, 01:22 |
#4 | |
Ravi Agrawal
Rep Power: 13 |
October 31, 2016, 01:29 |
#5 | |
Ravi Agrawal
Rep Power: 13 |
Can we use UDF to create multiple iso-surfaces for post-processing? Or you mean that create a formula or an expression at required locations to directly obtain these local coefficient in a text file, before initialization of simulation. Thanks. |
cfd-post, multiple, sections |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 08:23 |
Updating geometry in CFD post without resimulating | Trev0r | ANSYS | 0 | April 10, 2015 00:08 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 01:30 |
Parallel process & CFD POST | jypark | FLUENT | 2 | August 15, 2013 00:49 |
Poly lines in CFD Post | ashtonJ | CFX | 0 | December 2, 2010 03:46 |
