UDF syntax error problem which does not make sense to me! PLZ help |
ali
Rep Power: 17 ![]() |
Hi folks,
I receive a syntax error for the following line which does not make sense to me at all. I do not know what is wrong here. I have written UDFs many times before. I am not sure whether it is the version of Fluent that is causing this error or there is something else. I have to admit that it is the first time that I am writing UDF in v16.2. The error is apparently in the first line so I have deleted the definition between the bracket signs for simplicity real Re_t(cell_t c, thread *t){ ...} I am desperately looking for help. If you had similar issues please reply to this thread. Thanks, |
ali
Any idea people?
I am in desperate need of help. Don't literally have any clue what might be wrong in this regard. This is by far the simplest line any one could ever write. |
Error in the solver does not make sense | pawank | Main CFD Forum | 9 | September 25, 2016 05:04 |
udf or Parameters in fluent..plz help.. | nitman118 | Fluent UDF and Scheme Programming | 0 | June 6, 2013 06:51 |
HELP! How to make UDF for the adsorption isotherm? | Thanh | FLUENT | 3 | December 10, 2009 11:56 |
name variable in UDF using Thread : syntax error before numeric constant | Laurence Wallian | FLUENT | 0 | October 8, 2009 09:18 |
plz help. a UDF problem. | mehrdad | FLUENT | 0 | August 13, 2007 05:19 |
