Calculating Oscillating Aerofoil Angle of Attack |
October 27, 2016, 15:47 |
Rep Power: 14 |
I’m currently analysing a two bladed 2D vertical axis wind turbine in Fluent, where the blades also oscillate about their quarter chord position with changes in rotor position. The model is working correctly, and I’m writing the lift and drag coefficients in the X (streamwise) and Y directions with every time step for each blade to a .dat file, which enables me to calculate the normal and tangential coefficients. I would like to be able to calculate the effective angle of attack, but using the current coefficients I can’t establish a method of doing this, due to the angle of attack continually changing. I was wondering if there was a way of obtaining the lift and drag coefficient so that they are calculated orthogonal and parallel to the relative velocity for each time step, so that the effective angle of attack can be calculated? I’ve checked the documentation but can only find writing the X and Y directions like I’m using at the moment. Any advice/help would be much appreciated Kind regards MechEng86 |
August 20, 2019, 08:19 |
Same question
Rep Power: 7 |
I am facing the same issue. Have you found a solution for this? Thank you. |
change angle of attack in aerofoil | nicchani | OpenFOAM | 9 | November 14, 2020 04:51 |
[OpenFOAM] Plot Angle of Attack Next to Transient Pitching Airfoil | dancfd | ParaView | 6 | October 24, 2013 00:37 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | FLUENT | 2 | December 6, 2008 15:34 |
angle of attack | kiran | FLUENT | 0 | September 10, 2004 08:18 |
