How to modify Arrhenius rate parameters in Fluent ??
Old   October 25, 2016, 22:59
Question How to modify Arrhenius rate parameters in Fluent ??
Kashif Rashid
Kashif123 is on a distinguished road
I am simulating pulverized coal combustion using eddy-dissipation model (Turbulence-Chemistry Interaction). I have specified few reactions with their default Arrhenius rate parameters like (pre-exponential factor, activation energy etc.). The temperature that I am getting at the outlet of the burner is at least 300-400 K higher than what I am getting in the experimental setup, DO radiation model is also activated with all other 2nd order upwind. I read papers regarding this case in which they mentioned different Arrhenius rate parameters. I want to incorporate these parameters in my simulation instead of default values. But the problem is that Arrhenius rate parameters are not visible anymore, I can't change them further, only mixing rate is visible. Please guide how to modify these "Arrhenius rate parameters" . Figure is attached for the understanding of my problem.
Kashif123 is offline   Reply With Quote
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Accretion rate in Fluent Satish M FLUENT 0 August 26, 2016 02:00
rotor 37 choking mass flow rate fluent simulation sehs15 FLUENT 1 January 15, 2015 07:07
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
define volumetric reaction rate via UDF but how to set default Arrhenius rate richard ben Fluent UDF and Scheme Programming 0 May 11, 2013 09:05
