October 24, 2016, 01:44 |
Exhaust Gas Re circulation Model
Sumant Morab
Hi everyone,
I have designed 2D model for Combustion chamber with 2 egr pipes. But after the calculation, I observed in the results that instead of exhaust gas moving in pipes, fresh air is moving in upward direction. I tried patching some region in pipe with negative velocity but again fresh air was moving upwards instead of exhaust gas coming downwards. Please help me so as to avoid upflow of air in pipes. setup- Steady, non-premixed combustion, pressure-based |
UDF for Dusty Gas Model in porous media | MortI80 | Fluent UDF and Scheme Programming | 1 | March 24, 2016 08:25 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Convergence issues with Mixture model, when gas treatment changed to ideal gas | DVS | Fluent Multiphase | 1 | September 23, 2013 11:59 |
User Defined Real Gas Model | john | FLUENT | 1 | October 25, 2012 14:05 |
gas turbine combustor model - HELP! | Phil | FLUENT | 7 | May 2, 2007 06:40 |
