Farfield Setup for horizontel Turbine in Open Enviroment (Stationary) |
October 19, 2016, 00:42 |
Goeran Gabriel
Rep Power: 10 |
Hello.I need zour help
I want to set up the far field for an SRF of an one-blade horizontal wind turbine. The farfield should include: -Geometry of a cylinder -velocity inlet with the speed of the Wind (10m/s) -Rotational Motion Frame with the Speed of the windturbine (300rpm) (in this case I can solve a stationairy problem, if I put in an stationary blade) Aim: The Aim is to set up a far field which has straight Streamlines from inlet to outlet, if I look at it with the same speed as the Frame is turning. Problem: the streamlines always get an additional motion. In Case 1 I think the streamlines get a negative acceleration of the non moving outlet. In Case 2 I thougt it's just a problem with a bad mesh, but even with a finer mesh the results getting more worse! I tried different setups. check the images please. So would be happy if someone can figure out the problem and can help me (sorry for my bad english language) |
October 19, 2016, 08:06 |
To put it on a nutshell
Goeran Gabriel
Rep Power: 10 |
I need a cylindrical Fluid which has a homogenous translational velocity in the direction of its main axis and a homogenous rotational velocity around the same axis.
Thanks |
hawt, hawt wind turbine, motion frame, radial equilibrium, srf |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 15:07 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
regarding fluent setup for wind turbine analysis | er_ijaz | FLUENT | 0 | May 1, 2013 05:55 |
