help to interpret result
Old   October 13, 2016, 13:16
Question help to interpret result
Waid is on a distinguished road
I'm trying to simulate the air inlet through a small hole. The domain is 3D. I made a meshing by parts, with small cells near the inlet. I have used double precision, and second order discretization. According to the data, the gas flow is incompressible, then I assume constant density. For the turbulence model, I am using the k-e realizable.
In order to validate the mesh, I simulated for different meshes. In one of the attached figures, I plot the pressure drop vs. the number of elements in the mesh.
When I saw that figure, I thought my mesh was validated. However, later I decided to adapt the validated mesh (velocity gradient), and got a pressure drop of about 200 Pa.
I need help to interpret this result: my mesh is not validated?
I appreciate the comments!
Waid is offline   Reply With Quote
Old   October 14, 2016, 09:50
mome is on a distinguished road
Hi, fist thing - are the sides of your domain supposed to be walls, or do you intend to simulate a free jet? I assume you considered domain-size independence? Just saying.. you definitely have interaction with your BC on the sides.
Telling from the number of elements, in my experience you should have reached a mesh-independent solution but that's vague.. Maybe it is more of a problem how you refined in your last step? what does your mesh look like before and after?
-mo
mome is offline   Reply With Quote
adapt, mesh validation
Strange Result. jwh107 OpenFOAM 10 March 28, 2018 08:51
MRFSimpleFoam result checking Aadhavan OpenFOAM Running, Solving & CFD 0 December 8, 2012 05:52
How to display the whole result of a periodic model via one period result? dixylo FLUENT 2 February 23, 2012 05:11
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 06:25
LES result harrislcy FLUENT 1 December 28, 2009 07:29
