Problem of dynamic mesh in Fluent
Old   October 13, 2016, 13:03
Default Problem of dynamic mesh in Fluent
Qingsong
Qingsong is on a distinguished road
Hi everybody.
In dynamic mesh, I use a UDF code to allow a rigid body only to translate in one direction and rotate in one direction. But the rigid body panel shows values on all the directions of Rigid Body Angular Velocity. It should be zero at x and z direction.
If anyone knows what happened, please tell me. Many thanks.
Regards, Qingsong
Qingsong is offline   Reply With Quote
Old   October 14, 2016, 03:25
D.M
Davoud Malekian
D.M is on a distinguished road
this problem is mainly because of your code, try to change your UDF.
D.M is offline   Reply With Quote
Old   October 14, 2016, 03:49
Qingsong
Hi, D.Malekian,
I've checked my UDF code many times, and I think it's OK. My code is as following:
#include "udf.h"
DEFINE_SDOF_PROPERTIES(test01, prop, dt, time, dtime)
prop[SDOF_MASS] = 4184.769;
prop[SDOF_IXX] = 1;
prop[SDOF_IYY] = 11141.947;
prop[SDOF_IZZ] = 1;
prop[SDOF_ZERO_TRANS_X] = TRUE;
prop[SDOF_ZERO_TRANS_Y] = TRUE;
prop[SDOF_ZERO_TRANS_Z] = FALSE;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = FALSE;
prop[SDOF_ZERO_ROT_Z] = TRUE;
Old   October 14, 2016, 06:32
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
Originally Posted by Qingsong View Post
Hi everybody.
Regards, Qingsong
is it 2D or 3D ?
if it is 2D , i maybe you should put Ixx and Iyy zero . ( not sure , just idea )
amirhosseinfardi94@gmail.com
AHF is offline   Reply With Quote
Old   October 14, 2016, 11:05
Qingsong
Originally Posted by AHF View Post
is it 2D or 3D ?
The calculation is 3D.
Old   October 14, 2016, 11:06
Qingsong
Thank you for your reply.
I finally solve the problem.
Maybe there is a bug in ANSYS 17.1 version. A bug relate to the calculation in the first mesh layer near the wall. When I set up all the calculations in a lower version(V16.1), it works well.
spring-based dynamic mesh problem uhhaha2157 FLUENT 0 January 1, 2014 08:38
[mesh manipulation] Dynamic Mesh Diffusivity Problem dancfd OpenFOAM Meshing & Mesh Conversion 0 August 29, 2010 12:50
Dynamic Mesh Can not Be Used in FLUENT 12.0 lzgwhy ANSYS 1 April 18, 2010 19:19
Dynamic mesh + apaption in Fluent 12 ? klunker FLUENT 0 September 23, 2009 09:19
