need TUI or UDF post processing command help.
Old   October 6, 2016, 20:38
Default need TUI or UDF post processing command help.
Ash Kotwal
Ash Kot is on a distinguished road
my UDF is based on flow time in transient flow analysis, after 300 time step it generates new velocity value and inlet, outlet pressure value.
also on 300th time step, data is autosaved in .dat and .cas files.
is it possible to write UDF or TUI commands set, to create .xy plot files using fluent inbuilt post processing plots option. at 300th time step.
Ash Kot is offline   Reply With Quote
Old   October 7, 2016, 04:44
pakk will become famous soon enough
Yes, with a journal file for example. Look for that in the Fluent manual.
pakk is offline   Reply With Quote
Old   August 22, 2022, 04:36
sina
sina_sls is on a distinguished road
I want to use text command in UDF to be done every iteration . is it possible ? if yes how can i do it ?
Regards,
sina_sls is offline   Reply With Quote
Old   September 6, 2022, 16:12
HHOS is on a distinguished road
I always avoid UDFs whenever possible. You can do that with a journal file. You can call a journal every X iterations or timesteps by creating a command in the calculation activities tab. Something like:
/file/read-journal magic_journal.jou ()
In the magic_journal.jou file you will include the commands to save the pictures you want (of course instead of calling the journal you can just write them all in the execute commands box). It is important to include the iteration or the timestep in the naming of the pictures, otherwise it will always overwrite it.
You can do that by including the string %i for iterations or %t for the timestep in the file name you are giving to the picture. More information here.
Regards
HHOS is offline   Reply With Quote
Old   September 7, 2022, 02:41
sina
Originally Posted by HHOS View Post
Regards
Thank you for your response and guidance
Regards,
wind turbine - post processing er_ijaz FLUENT 0 September 30, 2013 06:28
post processing for CEL expressions Niru CFX 0 May 10, 2013 14:13
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 07:21
post processing in CFX11.0 u k jha CFX 1 September 17, 2010 06:53
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
