Access F1 Function from SST Model
Old   October 6, 2016, 09:39
Default Access F1 Function from SST Model
fanch33 is on a distinguished road
Hello evrybody,
I would like to access the values of the F1 blending function of SST model in an UDF, without compute it. I guess that the F1 function is stored somewhere and can be accessed directly. I looked in the headers file but I didn't see anything.
Thanks for your help.
François
fanch33 is offline   Reply With Quote
Old   October 6, 2016, 17:38
Lucky
Quick answer is to go to expert settings and enable the option to store temporary variables. Between this option and rp-getvar macro, you can access all Fluent variables.
LuckyTran is online now   Reply With Quote
Old   October 6, 2016, 18:54
Thanks for your answer.
I activated the storage of temporary variables using /solve/set/expert options.
I also used this command "(cx-send '(for-each (lambda (v) (pp v)) rp-variables))" to see all variables available in fluent but it seems to be only functions with constant values or true/false propreties.
If you have an idea I really appreciate it.
Thank you
Low Reynolds Number SST Model Josh CFX 41 June 4, 2023 20:00
Virtual inheritance problem while adding public member function to LES SGS Model konneym OpenFOAM Programming & Development 4 November 4, 2013 12:37
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
