validation with Ergun equation
Old   October 5, 2016, 13:13
Default validation with Ergun equation
mhs
mhs is on a distinguished road
Hi every body
I have simulated natural gas flow in a filter as a porous media in ANSYS fluent. the results, such as pressure drop, have a good consistent with the real case.
now I want to validate my simulation by comparing pressure drop across filter from ANSYS Fluent, with pressure drop obtaines from Ergun equation:
delta P= (150*viscosity*filter thickness*((1-porosity)^2)*Vs)/((Dp^2)*porosity^3) + (1.75*filter thickness*density*(1-porosity)*Vs^2)/Dp*porosity^3
and Dp is diameter of particles that made the porous media. as I know Vs is volume flow rate/cross section area.
all of parameters in the equation are clear, except Vs.
I put several value for Vs from ANSYS Fluent such as facet average for velocity magnitude, radial velocity, volume flow rate/area and... . but all of them have big difference with Ergun result. I thing the problem is with Vs and need help to find correct Vs in my case.
also my filter is like a tube with close end. flow enter from one end and exit from body of tube that is porous. my flow in turbulence and I have used RANS model for it.
Thanks for your attention
best regards
mhs
mhs is offline   Reply With Quote
Old   October 6, 2016, 02:45
Default deriving theporous media coefficients based on experimental results
shreehan Abd El-Ghafour
sh.a.ghafour is on a distinguished road
dear mhs,
are you sure that Ergun formula is the most appropriate method for your case?
i work in stirling regenerator and i used the experimental formula suggested into the FLUENT user‘s guide under subtitle:
"Deriving the porous coefficients based on experimental pressure and velocity data"
because you have experimental results , this method is the best for you
best regards
sh.a.ghafour is offline   Reply With Quote
Old   October 7, 2016, 10:53
Default Using the Ergun Equation to Derive Porous Media Inputs for a Packed Bed
mhs
dear sh.a.ghafour
first of all, thanks for your responding.
I don`t have the experimental data for V vs P. I just have pressure loss data in real case.
my procedure was like "Using the Ergun Equation to Derive Porous Media Inputs for a Packed Bed" part in fluent user`s guide.
I found alpha & C2 like this part of user`s guide (equation 7.19-17 & 7.19-18 in fluent 6.3 user`s guide ), and then put them into the software. now the results of fluent have a good agreementt with real data. but there is a big difference between Ergun pressure loss and fluent results for this parameter.
I thing the problem is with Vs that I read in false way.
mhs
Old   October 8, 2016, 13:11
mhs
dear sh.a.ghafour
first of all, thanks for your quick responding.
I did the procedure that is explaned in "Using the Ergun Equation to Derive Porous Media Inputs for a Packed Bed" in fluent user guide. and define my porous media base on that. (use of Ergun eq and darcy - forchheimer eq)
but now, my results have a good agreement with real case and a big difference with ergun delta P.
I think the problem is with my V , and I`ve read it from false place.
ergun equation, filters, porous media
How to add bodyforce in momentum equation in viscoelasticFluidFoam? arshoon OpenFOAM Running, Solving & CFD 0 April 9, 2013 11:03
Flow through porous medium Kiran AS FLUENT 6 September 16, 2011 08:38
Need help:about energy equation in CFX Stein CFX 4 July 2, 2009 23:31
question about energy equation zhou FLUENT 0 February 24, 2004 00:55
Boundary conditions in a Poisson's equation? vincent Main CFD Forum 4 April 16, 1999 03:19
