Copy solution setup and Boundary Conditions from a case file
Old   October 5, 2016, 02:32
Default Copy solution setup and Boundary Conditions from a case file
nonstopthinker is on a distinguished road
Hello All..
So i am trying to model rectangular coolant channels in 3d and i am applying boundary conditions and solution methods. In one of the cases I have got the converged solution. Now i want to copy the same setup and boundary conditions to another channel (different width and height - different aspect ratio). Kindly help as to how i can proceed with the same. I have tried using the write-bc, read-bc commands, but it still does not run properly on the new case. Kindly help.
Thank you.
nonstopthinker is offline   Reply With Quote
Old   October 6, 2016, 01:50
Lucky
Try write-settings! It is very similar to the write-bc commands though so you might encounter the same issue.
If everything else is the same, this is an extremely helpful command. But it requires that all surfaces are named the same, etc, etc. You might have to do some manual stuff first like making interfaces, etc.
Really what you need is a journal file that contains everything you did on case 1 and use it for case 2, but that's probably not the problem! I usually tinker with the new mesh just enough so that the settings file can be read over.
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Taylor Couette Setup and Boundary Conditions DaSh OpenFOAM Pre-Processing 2 September 28, 2017 13:02
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Parallel case setup boundry conditions snappyhexmesh oskar OpenFOAM Pre-Processing 5 September 11, 2009 02:12
