Laminar Wall Jet Flow over a Shallow Cavity
Old   October 3, 2016, 03:41
Red face Laminar Wall Jet Flow over a Shallow Cavity (help me)
Javad
javadkz is on a distinguished road
Hi
I want to simulation Laminar Wall Jet Flow over a Shallow Cavit.
The schematic diagram of physical problem taken in this
computational study is shown in Figures 1(a) and 1(b).
The two-dimensional incompressible laminar wall jet
flowunder the shallowcavity is taken into account.
the wall jet is assumed to be a uniform inlet velocity profile
and the jet density is assumed to be atmosphere air density
The uniform velocity inlet slot height (AI) is assumed to be
0.01, where, in Figure 1(b), AI is considered as jet inlet.
Based on no slip situation, 𝑢 = 0 and V = 0 along AB, BC,
CD, DE, EF, and HI.
Along GH:
𝜕𝑢/𝜕𝑥=0
how insert above boundry condition?
Along GF, the fully developed flow condition:
𝜕𝜙/𝜕𝑥=0 𝜙(𝑢, V, 𝑝, w)
Assume that the walls AB, BC, CD, DE, and EF are maintained
at adiabatic 400K.
Along the solid boundaries, 𝑢 = 0 and V = 0.
The inlet fluid temperature is set as ambient at 303K
Computational channel height is (AH) = 20ℎ and the
flow length 𝐿, that is, AF = 40ℎ, is found to be sufficient
for all the cases. Aspect ratios (AR = w/s), AR = 1
are used for simulation. The step length (𝑋u) is taken
as 𝑋𝑢=2ℎ
inlet velocities of Reynolds number are taken based on the hydraulic diameter of computational velocity inlet (ℎ) domain. 𝑋d is taken as downstream length of the computational domain. All the parameters are nondimensional.
Reynolds number=752
how calculate hydraulic diameter for this 2d problem?
how set air to incompressible mode?
i put setting to ideal-gas incompressible but in density contour density is not constant and my contour is not similar to particle's contour.
please help me
javadkz is offline   Reply With Quote
wall shear stress for laminar flow vitorspadetoventurin OpenFOAM Post-Processing 5 November 26, 2022 22:15
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
boundary condition of wall driven cavity flow ramin shams Main CFD Forum 2 June 2, 2004 05:01
