Fluent: Flow won't interact with rotating region |
September 26, 2016, 12:30 |
Hi everyone,
Some little problem, My project is to do a 2D Vertical Axis wind turbine analysis. This is a 2D analysis. I have set up FLUENT with no problem, there are 2 region, the boundary and rotating. Both have define interface. ANSYS version is 16.0 so it's contact region in Mesh Interface tab. The model is create in Solidwork and export to STEP. Airfoil is NACA 0018 Angular velocity is at 25 rad/s Inlet velocity is 20 m/s Outlet is atmospheric However, the result flow is seem not to interact with the rotating region at all, it's like they are both separated flow entirely. How could I make the flow interact? Should I specify a porosity? Screen: Best, and thanks for your time! T. Olsen, |
flow, rotating region, vawt, vawt wind turbine |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
Viscoelastic flow modeling in Fluent | Ankur Navra | FLUENT | 3 | July 26, 2013 06:56 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 21:41 |
How Fluent treat the pressure term in imcompressible flow | Ray | FLUENT | 1 | May 24, 2000 17:50 |
