NACA 0012, AOA=0, Lift=/0
Old   September 25, 2016, 02:15
Default NACA 0012, AOA=0, Lift=/0
jiyou
Freestream is on a distinguished road
Hi everyone,
I am a final year student in University of Glasgow doing Aeronautical Engineering. I am doing a project of numerical study on NACA 0012 in ANSYS Fluent.
I have read/watched tutorial on several sites and in Youtube over a month now.
Right now i am using a C grid and structured mesh with the following parameters (Refer to image):
AOA=0
Chord = 1m
X Distance upstream of airfoil = 7m
X Distance downstream of airfoil = 14m
Edge Sizing Control: Number of Division = 100
Bias Factor = 150
Mapped Face Meshing
No. of Elements = 40,269
Under Setup for simulation:
Turbulence Model: K-e (Standard)
Inlet Velocity = 5 m/s in x direction
The rest are as default values.
The result of force in the x and y direction are as follow (Retrieved from Result>Report>Forces>:
Forces in the (x,y,z): 0.068348119, -0.0029689099, 0 (N)
It is evident that the force in y direction is non zero (-0.0029689099).
Hope to seek guidance from experienced user!
Cheers!
Freestream is offline   Reply With Quote
Old   September 30, 2016, 00:02
jiyou
Hi everyone, i have an update on the result.
i attempt to refined the mesh and employ SA turbulence model with coupled solution scheme. At Re=3e6
the lift coefficient results i have are as follow.
AOA Cl Actual Cl**
0 -0.000715261 0.00
3 0.14828294 0.32
6 0.29564536 0.65
9 0.43876878 1.00
12 0.56909866 1.25
15 0.6879697 1.55
**Actual Cl data approximated from Abbot and Von Doenhoff's Theory of Wing Sections (page 462-463, reproduced below).
The 2D lift coefficient is extracted from
Report>Result>Force
by the following expression:
L=F_y cos alpha + F_x sin alpha
Hope experienced Fluent user can help me with the discrepancies observed from the simulation.
Thanks
Old   October 4, 2016, 04:36
jiyou
Hi everyone, i have resolved the problem by simply rotating the airfoil in Design Modeler, instead of resolving input velocity in the x and y direction.
the result have shown that fault lies in this area, but i cannot explain for this phenomenon.
lift, mesh, naca 0012, turbulence model, validation
Data for NACA 0012 Muntazir Main CFD Forum 1 March 28, 2023 02:59
2D NACA 0012 Airfoil Validation nvtrieu FLUENT 0 May 30, 2013 11:22
How to import NACA 0012 Profile in Gridgen maplepink Main CFD Forum 17 May 7, 2013 14:01
NACA 0012 Case Will Not Converge dancfd OpenFOAM Running, Solving & CFD 6 November 14, 2011 20:09
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 12:42
