Transient mode simulation (VoF model) mesh independence study problem |
September 18, 2016, 07:02 |
Yu Lu
Rep Power: 11 |
Dear All
I'm simulating a case with two fluids flowing in a pipe and try to capture the interracial instabilities of the two fluids. I've been using VoF model, Laminar, transient mode to calculate and so far it produced some results that are qualitatively quite well. However when I was doing mesh independence study, I kept increasing mesh density and I was getting different results each time! I judge the results by looking at the flow features after the same flow time. So I was wondering if the problem is I still have not reach a dense enough mesh or because the instabilities at the interfaces come from numerical calculations, I would never get same results when changing mesh settings? In this case, how should I proceed mesh independence study?? Many thanks for any suggestions. |
September 18, 2016, 11:43 |
Rep Power: 12 |
Hi, if you are calculating a transient solution, are you resolving unsteady features I assume? Are you comparing these structures at the same moment in time? If you do and still get significant changes, I'd say you did not yet achieve a mesh-independent solution for your type of flow. What about the average flow, would that be ok? The crucial point is if these changes have noticealbe impact on your quantity of interest. Can you try to quantify the mesh dependence you observe?
Cheers, Mo |
September 18, 2016, 12:10 |
#3 | |
Yu Lu
Rep Power: 11 |
Yes I am calculating unsteady time-dependent flow features and yes I am comparing results at exactly the same flow time when conducting mesh independent study. May I ask what's the best way to quantify mesh dependence ? At the moment I'm basically comparing flow features (structures) and I do observe differences when increasing mesh density. Please have a look attached a bit summary about the mesh I used (cross-section) and the flow features I was getting (contours of one phase). Many thanks. |
September 18, 2016, 12:35 |
Rep Power: 12 |
Hi, unfortunately, I'm not an expert for unsteady VoF solutions, so I fear there are other people who can help you better quantifying that in this case..
Although I don't know what quantity you are displaying the contour of, I'm guessing the restrictions represent some location of dilute second phase or so.. How do they form? If their formation is connected to some other quantity, you could compare their location and that other quantity. E.g. if they originate from the developping section of the pipe, you may have a chance to see differing boundary profiles up there or something like that. I think fixing a bias problem for pressure or velocity gradients is easier than for such structures? |
September 20, 2016, 18:30 |
Lucky
Rep Power: 66 |
I don't think these results are bad ones, namely you have shown that it is not mesh independent.
The VoF model is terrible at keeping track of interfaces, the VoF assumption is to completely smear the interface in the first place! Check your discretization schemes. Maybe you have more numerical instabilities as the mesh gets finer. I think you had a phenomenally great idea to compare flow structures at the same time! Great work! |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Mesh not converging as expected in a FSI problem | amrbekhit | CFX | 5 | September 8, 2015 03:36 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
How to study pressure drop of continous phase in VOF model | sajeesh | FLUENT | 4 | February 5, 2014 23:01 |
Turbine: Transient Simulation Problem | John C. | CFX | 7 | December 5, 2011 09:31 |
