FLUENT: Oscillating Results for Cd and Cl values
Old   September 14, 2016, 04:44
Default FLUENT: Oscillating Results for Cd and Cl values
Mario Alberto
mrwts is on a distinguished road
Hi guys!
I have been dealing with a simulation that gives oscillating results for Cd and Cl values. For Cd values the oscillations go up to 15% in some cases.
The main goal is to obtain an optimum position (aerodynamically speaking) for a wing in an amphibian aircraft. So, I am running a steady simulation with half the model (assuming flow symmetry). Spalart-Allmaras as turbulence model.
I am using coupled (therefore semi-implicit) as the discretization scheme. At the beginning, I tried out using segregated schemes, but I came across with Turbulence divergences no matter the under relaxation factor or discretization order I used, so I switched to coupled.
Any advice on how to get rid of those oscillations? As far as I understand, that kind of error occurs due to mesh problems or numerical errors.
I would appreciate any insights into this.
I tried to increase Courant number, but it didn't seem to cause any effect on the amplitude of the oscillations.
For reference:
The mesh has around 1 300 000 cells and I am iterating 6000 times.
mrwts is offline   Reply With Quote
Old   September 14, 2016, 05:03
Michael Brooker
Michael B is on a distinguished road
This can sometimes be due to unsteadiness in the flow and so the steady state struggles to converge to one solution. Consider running a transient to analyse this behavior further.
Michael B is offline   Reply With Quote
drag, fluent, numerical error, oscillations
