Question about the Large eddy simulation (Fluent)
Old   September 1, 2016, 05:48
Default Question about the Large eddy simulation (Fluent)
hamzaCFD is on a distinguished road
Hello, I'm new in this group, and I'm even a new User of fluent.
I'm simulating the turbulent flow of heluim in a curved pipe using the Large Eddy Simulation model (LES). And i found in the user guide that i can't define the mid plane of the pipe as a symmetry boundary condition when i'm using the LES model. I will really appreciate it if some one can help me because i can't find any information related the the subject.
hamzaCFD is offline   Reply With Quote
Old   September 1, 2016, 11:27
Please can any one help me ?
Old   September 1, 2016, 18:40
Zbynek is on a distinguished road
In LES, you capture the large eddies and model only the small ones that are smaller than your grid. So to say it in a very simplified way - if you use LES, you can visualize the large eddies moving in your domain vs. if you use RANS, the flow is all averaged. And as you know, turbulence is chaotic - which means there is no symmetry in it at all.
Because of these facts, you need to model the whole system, not just half - if you did model only half with the symmetry condition, then you would assume that the eddies on one side are the same as the eddies on the other side. And notice that the symmetry condition implies that there would be no flow across the plane. So as you can see, using LES with the symmetry condition does not give a physical sense.
Of course, you could use the symmetry plane if you used it with RANS approach.
Zbynek is offline   Reply With Quote
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Introductory books on Large Eddy Simulation q.z. Main CFD Forum 5 September 20, 2016 06:32
large eddy simulation 7sunnyshikhar Main CFD Forum 1 July 14, 2013 09:09
large eddy simulation amin_veysi OpenFOAM Pre-Processing 2 May 24, 2013 12:36
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
