Pressure input for Velocity Inlet in middle of 2D transient Simulation
Old   August 30, 2016, 15:54
Default Pressure input for Velocity Inlet in middle of 2D transient Simulation
Shekhar
Shekhaai is on a distinguished road
I am working on 2D Transient Simulation within a tube. At the start of simulation the inlet is closed and high pressure and temperature gases are allowed through exhaust. After certain time the inlet opens and air at P= 1.5 times ambient and velocity = 122 m/s must be supplied. How to define pressure without Initializing again ( I want all other parameters to be same, initializing will reset and is not favorable). Please suggest.
Shekhaai is offline   Reply With Quote
Old   August 30, 2016, 23:43
Real Name :)
ComputerGuy is on a distinguished road
Run your simulation from 0 to time t, where t= the time at which you'd like to change your inlet condition.
Then, change your inlet boundary condition once the simulation finishes the first run.
This can also be accomplished with a UDF, but this is the simplest way.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Pressure problems with inlet variable velocity jaimesdiegop CFX 2 September 1, 2016 03:31
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
outlet profiles of LES simulation as transient inlet b.c. for LES of a bend pipe Henny FLUENT 0 March 28, 2013 05:02
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
stagnation pressure in transient flow simulation K.S.Ravichandran Main CFD Forum 2 September 5, 2000 01:34
