UDM in two UDFS for one case
Old   August 26, 2016, 05:27
Default UDM in two UDFS for one case
Happy_weekend
Messi is on a distinguished road
Hi All,
I want to find a solution to a issue regarding the UDMS in two separate UDFs in my case.
Issue:
1, I am using two separate UDFS, UDF1 and UDF2. Each UDF has 5 udms, which will correspond to 10 udms in total (from 0 to 9).
2, I load these two udfs and start calculating my case. Fluent didnot show any error during calculation.
3, I need writing the data file for some udms during calculation. SO I use surface monitor to write out the data file of some udms.
4, Now, an abnormal result come out. All the value of the udms in my data file are zero.
5, Does anyone know the reason for this or how to solve this issue?
Messi is offline   Reply With Quote
Simple channel case using cyclicAMI will not converge cbcoutinho OpenFOAM Running, Solving & CFD 3 August 4, 2015 13:28
Cavity tutorial case shinde.gopal OpenFOAM Running, Solving & CFD 3 June 12, 2015 06:50
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 11:13
CFD Post - How to check for case in an expression pilakin ANSYS 0 September 26, 2014 05:44
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
