August 22, 2016, 05:40 |
Evaporation energy as heat flux
Johanson
Rep Power: 9 |
I'm modeling the temperature change in a room that has several water walls, to do this I've calculated the Latent heat from the evaporation and used that as the heat flux at the water walls BC.
Is this methodology correct? As I've found that results show very low temperatures at the wall (around -5000K when the heat flux is -200W/m2) |
August 22, 2016, 10:58 |
What about convection
#2 | |
Alex Gtz
Rep Power: 10 |
August 22, 2016, 11:41 |
#3 | |
Johanson
Rep Power: 9 |
The reason I'm doing it this way is to eliminate modeling the evaporation of water. |
August 22, 2016, 11:54 |
#4 | |
Alex Gtz
Rep Power: 10 |
BUT this method only consider convection. If you want to consider evaporation I think that you have to enable species transport equation. I've done that to display the humidity but I am not sure if it takes into consideration the heat flux created by the evaporation... maybe it worth to give it a try. Otherwise the method you used won't false the results within your fluid domain. It will only display a very low temp at your domain limits but the rest of the fluid domain is valid. |
August 22, 2016, 23:02 |
Johanson
Rep Power: 9 |
Alright thanks alex, I'll try this method.
evaporation energy, heat flux, latent heat |
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 03:27 |
Variable name for heat flux | peterle | CFX | 4 | February 13, 2014 02:21 |
How to define the heat flux in the interior interface between two phases | fangdian | FLUENT | 1 | November 18, 2013 07:23 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
