Moving reference frame for a particle in flow
Old   August 20, 2016, 18:57
Default Moving reference frame for a particle in flow
supermanks is on a distinguished road
Hi all,
I have a conceptual question which shouldn't take up too much of your time: I'm working on modelling the flow field around a finite-sized body which is being translated and rotated by a fluid (which is pressure-driven) . If I'm looking to model the steady-state situation (for both particle and fluid), can I get away with using a translating frame of reference alone, or would I need to use a rotating frame as well? Also, why?
Any quick ideas? TIA!
Regards
supermanks is offline   Reply With Quote
Old   August 22, 2016, 17:47
Any ideas, people?
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
particles leave domain Steffen595 CFX 9 March 7, 2016 17:19
parallel code samiam1000 SU2 3 March 25, 2013 05:55
Post processing of rotational moving reference frame Brathmann FLUENT 1 March 22, 2013 11:39
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 04:43
