Ramping Intialization Patch Pressure
Old   August 19, 2016, 21:18
Default Ramping Intialization Patch Pressure
Igor K
ikrash is on a distinguished road
Hi all,
I am transient simulating a 2-D axisymmetric CD nozzle with an inlet and discharge box on either side of the nozzle (to be able to see the fluid jet propagating through the nozzle and exiting).
Currently, I am initializing the simulation from outlet pressure conditions of 10 Pa and then patching the inlet box with 50 kPa.
Simulations run relatively well and convergence is observed, however, I was wondering if anybody here has written a UDF to ramp the patch pressure from outlet conditions up to 50 kPa to reduce the gradient and minimize rarified gas dynamic effects.
Thank you.
ikrash is offline   Reply With Quote
initialization, patch, ramping
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
