August 18, 2016, 09:36 |
How to resemble a compressor in Fluent ?
ahmad salah
I am designing a hyperloop capsule with a flow speed of 300 m/s (Pressure Based and viscosity: Spalart-Allmaras) and tube pressure (Operating Pressure) of 500. The capsule is designed with a compressor in front of it. My problem is that I don't know how to resemble the compressor in the Fluent. I tried the inlet vent, the intake fan, and the mass flow rate options in boundary conditions settings but I keep getting shock waves after some speed (usually between 150 and 200 m/s) due to the high speeds larger than 300 m/s between the sides of the capsule and the tube. I would appreciate it if you can help me. My regards. |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 09:08 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 03:48 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
