August 10, 2016, 05:09 |
HVAC - Humidity affecting the temperature
Alex Gtz
Rep Power: 10 |
Hi everyone,
I am simulating airflows within a swimming pool building. I had some good results, with a air temperature of 27°C as desired. Then, I decided to implement the humidity. --I have already done that previously and it worked fine -- I activate the Species Transport Equation, with volumetric reaction, eddy dissipation and mixture template as settings. Options : Inlet Diffusion. For the BC I put the specific humidity as H2O mass fraction (inlet, pool interface and outlet). After running the simulation, my air temperation has dropped and is now 15°C. I don't understand why the Species Transport is affecting the temperature. Any help is very much appreciated |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 12:43 |
outlet temperature | jigneshrohit99 | FLUENT | 1 | March 25, 2016 14:26 |
where is the calculation of the temperature field | Tobi | OpenFOAM | 1 | July 30, 2012 11:40 |
difference of temperature | HKH | FLUENT | 0 | January 28, 2010 03:45 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 18:31 |
