Mert
Rep Power: 10 ![]() |
Hi everyone,
I am trying to do an analysis of a pump impeller. And I have to show that my impeller is pumping the fluid. For example; my pressure inlet is 0 Pa and outlet pressure is 10 Pa. I want that the rotation energy will beat 10 Pa and fluid flow occurs. Is it possible? If it is, how can I make this happen ( which model, frame motion or mesh motion) I need your help ![]() |
#2 | |
Onur Özcan
Rep Power: 12 ![]() |
Mert
First one is my model and second one is how i want to do the simulation
Onur Özcan
Mert
How do you get meters of head from a pump at the ground ? It is the same, rotational pump energy is converted to the potential or kinetic energy of the fluid.
But I dont know how to apply this tought to my case. |
axial flow pump, impeller, pump, pump boundary condition |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 06:42 |
Flow simulation in Axial Pump Impeller | aungkyaw | Main CFD Forum | 1 | December 9, 2014 02:02 |
Pump Cavitation Analysis in ANSYS CFX | techCAE | CFX | 6 | July 3, 2013 06:37 |
3d centrifugal pump analysis in fluent_turbo | manuvel | FLUENT | 0 | May 4, 2012 02:54 |
Simulation of an Axial Impeller | cnchilavert | CFX | 1 | October 15, 2011 02:01 |
