Error Code:cannot create surface from sliding interface zone |
August 5, 2016, 00:26 |
Steven Sze
Rep Power: 10 |
I am new to Fluent, and i am currently simulating a 2D wind turbine. I am using sliding mesh method. I had created two region, a rotating region in the middle, and a boundary region which is outside of the rotating region. I have set the circumference of the rotating region as 170mm in diameter, and the circumference of the boundary region as 170.01mm in diameter. After the meshing, when i export it into Fluent, the setup shows "Cannot create surface from sliding interface", and there are two new interfaces appeared in my boundary condition tab, rotating contact region and boundary contact region. when i click the "Mesh Interface", there is a "contact region" in it. Any advice is very very much appreciated. I am having trouble with this for a long time now. |
contact region, error, sliding interface |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 02:07 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
