Conjugate Heat transfer with phase change
Old   August 4, 2016, 09:02
Default Conjugate Heat transfer with phase change
cfdsolve is on a distinguished road
I am solving a case of conjugate heat transfer with phase change. The geometry is helical coil containing tube side fluid (which changes phase) and an annulus surrounding this coil containing shell side fluid. For boiling, I've used:
Eulerian (Boiling,CHF) model
Material properties are constant
OPerating pressure is atm (while both fluids are at different pressures)
BCs are two velocity inlets and two pressure outlets (no vapor at inlet, no liquid at outlet)
PV Coupling is SIMPLE with all discretization schemes of 1st order
Standard initialzation with default settings
URF's are all default, only vapor fraction URF is 0.01
Problem faced is that case diverges after performing about 600 iterations. Is there any way to stop the case divergence?
Mesh elements are about 4.5 million.
Any help in this regard by forum members will be greatly appreciated.
cfdsolve is offline   Reply With Quote
UDF to change heat transfer coefficient with wall temperature emmkell Fluent UDF and Scheme Programming 18 August 7, 2018 04:44
Conjugate heat transfer + phase change JohnJohn8 Main CFD Forum 0 July 29, 2016 08:20
VOF with conjugate heat transfer vs138 Fluent Multiphase 1 November 12, 2014 09:52
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
