fluent subsonic wing analysis problem
Old   August 3, 2016, 10:41
Default fluent subsonic wing analysis problem
Fatih
fatihcoban is on a distinguished road
I have been trying to analyze a wing in fluent and trying to get the best cl and cd values at different aoa. I create my model in catia, for mesh i used fluent meshing tool. I create my geometry and mesh model according to cornell's 3d wing analysis tutorial. My problem is that I haven't got a desired value for cl and cd yet. I analyzed it at 0,2,4,6 aoa. At 0 aoa i saw 0.45 cl and 0.035 cd and at 6 aoa i saw 0.61 cl and 0.077 cd values. I know that these values are wrong. When I look at my airfoil's cl and cd values at the same aoa they are very different. Also I analyzed the airfoil using Xfoil and wing using XFLR5 modules then compared the results. See the results below.
Airfoil using xfoil
0 aoa cl 0.54 - cd 0.009
6 aoa cl 1.19 - cd 0.01
wing using xflr5
0 aoa cl 0.6 - cd 0.013
6 aoa cl 1.14 - cd 0.045
wing using fluent
0 aoa cl 0.45 - cd 0.035
6 aoa cl 0.61 - cd 0.077
fluent solution case;
model: Spalart allmaras
material: constant-air-1.007 kg/m^3-1.726 e-5 viscousity
velocity 26 m/s
outlet pressure 0
reference values from inlet-reference area 1.13 m^2-reference lenght is wing chord
solution method coupled-second order
Could you please help me the solve this problem?
fatihcoban is offline   Reply With Quote
MPI problem with fluent aryanet FLUENT 17 October 30, 2017 22:04
3D Wing Analysis Ed FLUENT 13 July 26, 2014 06:12
Acoustic Analysis using Fluent and ANSYS mechanical ankit1512 ANSYS 0 November 10, 2013 19:46
3d wing analysis in fluent !! urgent help . beginner sam15 FLUENT 7 August 3, 2012 07:01
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
