rotating molten metal casting simulation in implicit form
Old   August 3, 2016, 08:23
Question rotating molten metal casting simulation in implicit form
YongHanLee
ACDFD is on a distinguished road
hello guys
I'm trying to simulate titanium centrifugal-casting. since Explicit model take a long time, I chose Implicit model. But when I trying to rotate the whole partbody, molten titanium does not flow into partbody. And when I remove rotating condition, It's successfully work. I don't know what's the problem and which conditions should I fix. Here's my setting in Fluent and figure of my project.
General : Pressure based / transient / Absolute velocity formation
Models : VOF - Implicit
Cell zone conditions : reference frame - 26 rad/s (No mesh condition)
Boundary conditions : 0.001 m/s , titanium multiphase - 1
Solution method : SIMPLE - Least Squares Cell based - PRESTO! - QUICK - Compressive
I wonder Implicit model and rotating condition does not fit together. Error ONLY occurs when I set rotating condition. Should I use Explicit model even though it takes a long time?
Thank you all guys who read this thread and I hope you leave a comment.
Regards,
Dox Kim
ACDFD is offline   Reply With Quote
Old   November 17, 2017, 03:16
Smile Rotating Molten Metal Casting Simulation
James Charles
mangaliron is on a distinguished road
Casting of molten metal is important in many industrial processes.Centrifugal casting is used for manufacturing pipes, bearings, and many other structures. A cylindrical enclosure is rotated rapidly and steadily about a horizontal axis, as in Figure P7.64. Molten metal is poured into the rotating cylinder and then cooled, forming the finished product. The reactive alloy is melted in a cold crucible using an induction coil and then the complete crucible-mould- running system assembly is rotated through 180degrees to transfer the metal into the mould.
mangaliron is offline   Reply With Quote
casting, implicit, molten metal, rotating, rotation
the rotating domain simulation lius Main CFD Forum 3 July 8, 2017 09:33
ROTATING TURBINE BLADE SIMULATION Anant FLUENT 2 March 31, 2011 11:57
modification for rotating cylinder simulation zonexo Main CFD Forum 3 July 21, 2006 15:24
Stirred tank with baffles simulation using single rotating reference frame M.Zhou FLUENT 1 March 5, 2000 16:01
Casting Process Simulation Anil Shenoy Main CFD Forum 1 February 22, 1999 12:56
