Velocity profile is not turbulent (OPEN CHANNEL FLOW)
Old   August 2, 2016, 16:59
Smile Velocity profile is not turbulent (OPEN CHANNEL FLOW)
Rui
roi247 is on a distinguished road
Hello Everyone!
I'm simulating flow in a rectangular channel using LES. Depth=0.0975m, Velocity=0.495m/s, Width=0.381m L=10D=0.975m ReL= 96482= D*2*0.495/(10e-06)
Boundary conditions are velocity inlet, Pressure outlet, no-slip wall, symmetry free surface. The yplus of first layer close to the wall is guaranteed to be smaller than 1. Initial conditon, velocity magnitude all over the mesh.
No matter how I change thesetting (Mean velocity, UDF (power law),add some perturbation 10% turbulent intensity) . It still does not look like turbulent velocity profile.
I changed the channel to be more inclined (from 0.01 to 0.03) and changed the setting to be periodic boundary condition. Translational periodic boundary condition is used currently. Specifying the mass flow rate based on the discharge in the channel. 10 flow-through time is used
/mesh/modify-zones/make-periodic outlet inlet no yes yes
/define/periodic-conditions/massflow-rate-specification 18.346916 0 0.5 2 0 -0.029986509 -0.9995503
define/boundary-conditions/zone-type watersurface symmetry
Still laminar velocity profile
I even add some small square to generate more turbulence at the inlet of the simulation. using periodic boundary condition. Still Laminar velocity profile.
Could you please help me ?
Thank you !
Roi247
roi247 is offline   Reply With Quote
Old   October 5, 2016, 07:52
muhamed
Mohammad80 is on a distinguished road
Please, do you have a UDF file for inlet velocity profile of an open channel case?
Mohammad80 is offline   Reply With Quote
Old   March 15, 2017, 08:30
daroz is on a distinguished road
Originally Posted by roi247 View Post
Hello Everyone!
Thank you !
Roi247
Heve you solved your problem? I am facing a very similar situation. If yes, please let me know what you did =).
daroz is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
3D parabolic velocity profile for channel flow seetaratnam FLUENT 1 August 10, 2016 04:08
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
