Flow around a porous cylinder
Old   July 30, 2016, 03:43
Default Flow around a porous cylinder
Ema40 is on a distinguished road
Dear Members,
I am simulating a 2D problem, with a water flow around a circular cylinder. The cylinder is porous; I set the porosity in "Cell zone conditions" for the cylinder.
1) For porosity higher than 0.5 the solution converges, but for porosity lower than 0.5 it does not converge. I have tried to change the numerical schemes (Quick, second order, etc.), the pressure velocity solving (Piso, Simple, Coupled, etc.), the turbulence model (k-eps, k-eps RNG, k-omega, etc.), the time step (also of more than 10 times lower!). The soultion diverge both in stationary and in transient formulation. The divergence starts from the inside of the cylinder.
2) How can I monitor the Drag at this cylinder? The boundary between the cylinder and the surrounding domain is an interface, not a wall, but Fluent can monitor the drag only at wall surfaces.
Can you help me?
Thank you very much!
Ema40 is offline   Reply With Quote
Old   September 27, 2016, 07:06
Anirudh Kulkarni
Tempest is on a distinguished road
Did you get a solution for your problems?
Tempest is offline   Reply With Quote
Old   June 4, 2017, 07:59
wxn
sofina
wxn is on a distinguished road
Hi Ema40
HiTempest
Did you get a solution for your problems? I also want to know.
wxn is offline   Reply With Quote
cylinder, drag coefficient, porosity, porous body
Flow through small cylinder recirculated inside larger cylinder. Keesie FLUENT 1 July 28, 2016 05:30
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 11:05
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
