Dynamic Mesh Settings for compressed FSI
Old   July 26, 2016, 12:11
Question Dynamic Mesh Settings for compressed FSI
ANSYS_Man is on a distinguished road
I am trying to simulate a lubrication theory problem where a fluid is being compressed between two rubber rotating rollers to the point where the fluid needs to be ~0.1 mm by utilizing FSI coupling. No matter my dynamic mesh setup I have been getting negative mesh volumes. I have tried reducing my time step down to 0.001 and have the following settings for dynamic mesh:
Methods:
Smoothing-Diffusion, Diffusion Function(boundary-distance), Diffusion Parameter (1)
Remeshing: Local Cell, Local Face, Parameters (Use defaults)
Dynamic Mesh Zones:
Surfaces in contact with rollers: System Coupling with the cell height set as the specified element size from the fluid mesh.
All other surfaces: Deforming with zone parameters set based off the bounds from the zone scale info
I am relatively new to ANSYS Fluent and this is my first time using FSI coupling. Any help would be greatly appreciated!
ANSYS_Man is offline   Reply With Quote
ansys 17.0, dynamic meshing, fsi 2-way coupling, remeshing
Dynamic mesh using profile sanjeetlimbu Fluent Multiphase 3 April 19, 2018 10:49
FSI Dynamic Mesh Separating? dcp2387 FLUENT 0 June 20, 2016 18:50
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 12:39
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
