Can't grow prism mesh off a Wrap-type object using zone-specific growth option
Old   July 23, 2016, 03:33
Exclamation Can't grow prism mesh off a Wrap-type object using zone-specific growth option
Ivan
Flashfake is on a distinguished road
Hey All,
I have linked a thread that has also not been answered but is very similar.
I am using ANSYS 16.2, but it seem to be on other versions too.
When trying to create prism mesh on a wrapped object, I get the following error:
"Prism Meshing is not supported for face zones of mesh objects"
The only way that I seem to be able to create the prisms is to go off an object based surface. The issue is that object based surfaces cannot selected in in the automesh.
My procedure to getting to this point is as follows:
  1. import the geometry. (I use a tolerance of 0.01m and have import CAD curvature on) Import name-selection: on
  2. make a material point for the fluid and change boundary types to be correct. Any surface names that I need to change I'll do here too.
  3. I generate a size field with relevant curvature, boi and proximity settings.
  4. I then wrap the object to see what the mesh looks like and identify any locations that I might have missed or where I could relax the size-functions around.
  5. After I am happy, I export the size-function. (just in case and I use it for re-importing geometry if needed)
  6. I select automesh and select the wrapped object (its also the only object to select)
  7. Under grow prisms, I select zone-specific. Click on 'set' next-door and orient the growth based of the material point.
  8. I set all my conditions under growth and click apply.
  9. If I click create, the following error pops up: "Prism Meshing is not supported for face zones of mesh objects"
  10. I do not click create, however I feel that is where the issue lies.
  11. I set up the tet volume fill using size-field.
  12. Hit apply in the automesh
  13. click mesh. The following error comes up: "Apply zone specific prisms on at least one of the face zones of selected object."
I clearly already have as it is in _prism_fluid group that was created earlier in grow prisms.
Any assistance would be vastly appreciated.
I would like to know what I am doing wrong, I really do not understand what the error could be from.
Is it an import setting? I have tried a few options with no avail. Some naturally do not keep the names for the faces etc, however the issue still persists.
Thanks for any help that you can give in advance.
Flashfake
Flashfake is offline   Reply With Quote
fluent mesher, wrapper
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
