How to check for separation
Old   July 22, 2016, 05:38
Default How to check for separation
Niels Hawinkel
NielsHaw is on a distinguished road
I'm designing a low-drag vehicle and I'm trying to eliminate all separation. When i plot the skin friction coefficient, my lowest value is 0.004. My question now is: At what value can you assume you actually have separation? Does the skin friction coefficient value have to be exactly zero, or is there a threshold value?
Thanks in advance
NielsHaw is offline   Reply With Quote
Old   July 29, 2016, 08:52
Default ggg
Niels Hawinkel
Anybody pls?
Old   July 29, 2016, 10:03
nm
nvarma is on a distinguished road
usually it goes to zero and may be a little bit to the negative side (flow reversal).
You can also try plotting stream wise pressure gradient to ensure thats separation
nvarma is offline   Reply With Quote
separation
Mesh check failed subhas.hunasikatti@gmail. FLUENT 0 January 19, 2014 05:09
[ICEM] Understanding check mesh output kotimari ANSYS Meshing & Geometry 0 July 15, 2012 09:33
faceZones and topological check mturcios777 OpenFOAM Programming & Development 0 June 15, 2012 14:48
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
Cell check and Boundary check errors AB Siemens 4 October 28, 2004 14:04
