Flow uniformity at outlet - adjoint optimization |
July 17, 2016, 08:24 |
F.F.
Rep Power: 14 |
Dear community,
I want to define flow uniformity as an observable for an adjoint optimization with Fluent v16. The geometry is a simple 2D 90° pipe bend. From the webinar "The ANSYS Fluent Adjoint Solver" I know this option exists. Can someone give me a hint? In a next step the simplified 2D model should be extruded by 360° so that a radial diffusor is created. The observable should also justify this geometry. Any help is really appreciated! |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 06:42 |
Flow uniformity measurement | Many | Main CFD Forum | 0 | February 1, 2016 10:53 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
