Evaluating UDF variable to change boundary conditions |
Rep Power: 11 ![]() |
I have an adjust UDF that calculates a variable. Based on this variable, I need to change the inlet/outlet boundary condition between pressure inlet/outlet and wall. For example, if the variable is <0, then I would need to change the "pressure-inlet" to "wall." I know that I need to use text user interface (TUI) to switch the boundary conditions. Is it possible to use TUI scheme to conditionally evaluate a UDF variable? If so, how is this done? If not, what is a potential solution around it? Thanks |
Pressure boundary condition on walls for incompressible flows | odellar | OpenFOAM Pre-Processing | 26 | May 10, 2021 10:49 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 05:59 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
