Rep Power: 0 ![]() |
Hello everybody!
I am doing a 3D steady simulation of the interior of a 16 MWth biomass grate-fired boiler. The biomass burning bed and the grate have been excluded from the geometry and in their place a mass-flow-inlet boundary has been set. This boundary has to be divided in 6 different zones, one for each section of the underlying grate. Each sections have different values of massflux. To set these conditions I have used an UDF specifying a step-wise massflux profile (6 steps). (So far I have only done simulations without reactions, as if no combustion occurs. The fluid is pure air for now.) My problem is that when I hook this UDF to my case residuals stabilize with little fluctuations around 10^-2 - 10^-3 after more than 5000 iterations. This can't obviously be accepted as a converged solution! On the other hand when I use a uniform value of massflux on the boundary, without using any UDF, then residuals drop even under 10^-6. The reference settings of the simulation are: type: 3D, double precision, steady solver: pressure-based turbolence model: k-epsilon standard energy: activated species: not activated fluid: air as ideal-gas pressure discretization scheme: PRESTO! all other discretization scheme: First Order p-v coupling: SIMPLE I have already done several tests trying to change different things such as type of mesh, turbulence models and type of solver. Mesh tested: full hexa, full tetra, hybrid Turbulence models tested: k-epsilon realizable, k-omega standard, k-omega SST p-v couplings: SIMPLE, PISO, Coupled I have also tried to bypass the UDF usage by directly dividing the single boundary in 6 different boundaries, but the problem is always the same: uniform massflux value residuals drop, stepwise profile high residuals values. Any suggestions? Thank you for the attention. |
convergence problem, massflux profile, stepwise profile, udf |
Read profile file from UDF | DonQuijote | Fluent UDF and Scheme Programming | 0 | February 18, 2013 11:56 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
History Convergence: Graphical problem | Bedotto | Fidelity CFD | 1 | March 17, 2010 23:40 |
UDF parse error at profile function line | Wiggy | Fluent UDF and Scheme Programming | 1 | July 27, 2009 15:59 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 05:24 |
