Counter flow diffusion flame simulation using Fluent (Flame temperature too low)
Old   July 11, 2016, 04:57
Default Counter flow diffusion flame simulation using Fluent (Flame temperature too low)
upender singh
upender is on a distinguished road
I am trying to model a counter flow diffusion flame using ansys fluent with fuel/oxidiser as methane/air.
The problem is that the flame temperature(800 K) is much lower than what it should be(>1600 K).
I am using Non premixed combustion module with steady diffusion flamelet and adiabatic energy treatment since combustion is instantaneous process. I am using a standard 30 species chemkin reaction mechanism from standard mechanisms library.
My PDF table seems OK as The plots show a max temperature of 1800 K at a mean mixture fraction value of 0.1. The geometry is a simple cylinder with two inlets in the axial direction and outlet in radial direction(image).
The Dia of two inlets is 60mm and the gap=10mm.
Can any body explain why am I not getting the desired temperature? I would be happy to provide any further information if required.
https://postimg.org/image/on8od81jb/
upender is offline   Reply With Quote
Old   July 11, 2016, 07:05
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
what about radiation. Have you activated it ?
How do you ignite your flame. How about solving turbulence and flow equation first, then activate PDF for ignition...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 11, 2016, 07:24
upender singh
Hi Ali,
Thanks for the reply. No, I have not activated the heat transfer and radiation modules. I am keeping it strictly adiabatic(Am I wrong?). I am using a 30 species chemkin mechanism to generate the flamelets. Then I generate the PDF table. Then I go for the boundary conditions. The mean mixture fraction for fuel inlet is 1 and the oxidizer inlet is 0. The velocities at both ends is 0.1m/s. I initialize the solution through all domains and run it for 200 iterations. It converges on 80th step.
If you think that something is wrong in my approach, please point me in the right direction. I have never used the combustion modules before.
Regards
Old   July 11, 2016, 20:00
diamondx's Avatar
Ghazlani M. Ali
Nothing looks, are you comparing it with experimental data ??
Regards,
Ali
combustion modeling, flamelet model, non premixed combustion
Re: How to use more than 50 species for flame simulation in Fluent platform? drah FLUENT 0 April 14, 2016 09:37
Simulation of flow around a ship hull using fluent and Openfoam manoj_nav FLUENT 0 December 17, 2015 02:05
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Flow Simulation SOLIDWORKS or ANSYS Fluent CFD beginner Main CFD Forum 0 March 31, 2015 05:12
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
