July 5, 2016, 10:22 |
Surface tension values
Apiano Morais
Rep Power: 10 |
Hi guys... I am trying to simulate electrowetting problems. So far, it is working fine, but I really need to check if my udf (define-property) is working properly.
Does anyone know how to export or visualize the surface tension values in VOF? |
July 6, 2016, 09:20 |
Rep Power: 11 |
I think you need to create User-Defined Memory (UDM). See the Fluent Customization Manual.
July 6, 2016, 16:10 |
Apiano Morais
Rep Power: 10 |
I'll try this... it seems to be the right path... thanks
fluent, surface tension, udf |
VOF +surface tension force modeling+ open channel flow+cyclic region= fatal error? | SJSW | Fluent Multiphase | 2 | November 18, 2014 05:15 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
continuum surface tension model | yukn | Main CFD Forum | 0 | October 8, 2011 07:43 |
Surface tension problem. | Kes | FLUENT | 0 | May 19, 2008 23:49 |
Surface Tension Gradient | Alisher | FLUENT | 0 | March 26, 2008 05:26 |
